-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   wiper motor question (http://forums.pelicanparts.com/showthread.php?t=133717)
Kevin Powers 10-30-2003 05:35 AM
the wipers will not return to the "rest" position when they are turned off. they stop where ever they are. is there a quick fix for this?
kevin
red-beard 10-30-2003 05:45 AM
Sounds like the main red wire is not connected to the motor or the limit switch is internally broken.
Kevin Powers 10-30-2003 05:48 AM
thanks james, the wire is connected on the motor itself?and limiting switch is where?
kevin
red-beard 10-30-2003 06:02 AM
The limit switch is internal to the motor assembly (not the black part, but the silver part). There are 4 wires which connect and one is hot power for the wiper return. It it always hot, so the motor will return.
Unfortunately ro properly diagnose the wiper motor, you have to pull the gas tank....
James
SteveStromberg 10-30-2003 07:44 PM
When you pull the tank splice in a Three prong connecter into the Wires then you wont have to remove the expansion tank to unhook the gauge sender. Steve
Kevin Powers 10-31-2003 05:07 AM
thanks steve. i did that same thing to my silver car when i was putting it together. it's a nice trick. another one of those " why did the factory do this that way?".
kevin
72' 914 roller,for sale
73' way not original 914, mine
75' very original 914, hers
70' ford p/u "sport custom" package
85' jetta with 238k
93' ford escort wagon
