throttle cable
My 76 was converted to 44 Webers, will a stock cable work or does it have to be modified. Is there a direct fit one available.
I'm still looking for late model Perdrini's, unpolished and a source for an original style (black & gray) carpet set.
Old 10-30-2003, 11:22 AM
skline's Avatar
The stock cable will work with the carbs. I run one on mine with a pair of 45's. No Pedrini's however, I just never liked them.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 10-30-2003, 11:34 AM
I just replaced my throttle cable on my 74 w/Weber 44IDFs... I bought the Terry Cable from our illustrious host. Very easy, I must say, to install - I was lucky because I had no carpet in at the time.
One thing I was concerned about was that my cable was about 10 or so inches longer than I needed... so i had to cut it..
I need to find something to bind the threads of the cable before they start to unravel.. any ideas?
I suppose I could use a burnz-o-matic on the frayed ends to 'solder' them together?
I'd rather have a bottle-in-front-of-me than a frontal lobotomy.
Old 10-30-2003, 01:04 PM
Zeke's Avatar
Solder works and you can solder the wires before you cut for a nice, clean cut. Also, check out the cable ends at bike shops.
Old 10-30-2003, 09:48 PM
