D7N7MASTER's Avatar
Question No Dash Lights
I've owned this teener for 4 years. In all that time the dash lights have never worked. It's not like it was a top priority - but now that most everything else is either rebuilt, replaced or removed I wouldn't mind having functional dash lights. any suggestions? I've checked the bulbs & that's not it...
thanx
www.pelicanparts.com/gallery/d7n7master
Old 11-06-2003, 09:42 AM
jkeyzer's Avatar
Get a voltmeter and see if you have voltage at the bulbs. Then trace the wires back to the headlight switch. Chances are something is not right there, either a hookup problem, broken wire, or the variable resistor inside the switch is broken (happened on my 911).
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 11-06-2003, 09:56 AM
grind weld build
sean_V8_914's Avatar
I think the dash lights share a common ground. If they are all out, I would look for a fault in common
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 11-06-2003, 11:09 AM
SGB SGB is offline
SGB's Avatar
Lightbulb
All the dash lights feed through the reohstat (sp?) in the headlight swich- when working it is brighter clockwise, dimmer counterclockwise. I'm pretty sure it is a white wire with red stripe (on my 73)- but you should check the diagrams here at PP. If you do a search on "improved electrical diagrams" you will come up with some just fantastically easy to understand schematics that are for a 74 i think, but will certainnly greatly enhance your understanding. Find the HL switch, then follow wires untill you see what color is going to instr bulbs. You can bypass the light switch. Just pull off the spade connector and put it on the fuse that the parking lights are on (i think its 5 but you should check 'cause i'm too lazt to do it). There may even be a free male tab to slid it onto.
-Scott
My gallery page
Old 11-06-2003, 07:06 PM
i just went through this on my new 75'. check the #7 fuse. then check the wires to the rear defog switch/light on the center tunnel. lift the carpet to make sure the hot lead is not chaffed or making contact to the tunnel. mine was and it popped the fuse.
kevin
here? not so much i think. high five!!!
Old 11-09-2003, 07:11 AM
Toast's Avatar
Cheepest and most common problem is either a fuse or a voltage regulator.
73 Yellow 2.0
86 Toyota 4X4
Old 11-10-2003, 12:24 PM
turn the headllight knob all the way to the right. sorry for stating the obvious
Old 11-10-2003, 10:17 PM
