415pb's Avatar
Case Sealant......Pic
Would my case be okay if I used this sealant. I wanted to put the case together this weekend. I got some of this stuff, but I remember reading somewhere to not use silicone based sealants. Is there any other sealant that is recommended, that I can pick up from my local auto parts store?
Thanks,
Rod
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 11-14-2003, 07:17 PM
Zeke's Avatar
Permatex 3H Aviation Sealer would be better. Silicone can have too little wok time and if you don't get the cases buttoned up fast enough, they may leak, or worse, they may not come together all the way leaving your main bearings loose on the crank.
Old 11-14-2003, 07:26 PM
415pb's Avatar
Milt, do they sell 3H Aviation sealer at local auto parts stores, if not where could I get some?
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 11-14-2003, 07:32 PM
DuckRyder's Avatar
Send a message via AIM to DuckRyder
What about anerobic from a GM dealer, they use it in transmissions.
Won't dry until the parts are torqued together (might dry too well then though)
Old 11-14-2003, 08:06 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Yamabond at the Yami dealer in the morning. It the same stuff as we use Three Bond 1104. Steve
Old 11-14-2003, 08:40 PM
Zeke's Avatar
Well , I bought mine at a VW shop. The folks over on Shop Talk Forums like Curil K2. Here's a good trick if you are starting from bare cases. Assemble the cases empty and lightly torque. In a dark room, shine a light in the cases and look for light at the parting line. If all is well, use a very small amount of case sealant on one case half spreading evenly across the whole surface just before setting the other case half in place on your final assembly.
Old 11-14-2003, 09:06 PM
skline's Avatar
I agree with Zeke, That is what is recommended by all the VW engine builders I have talked to and it is what I used on mine. Works great.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 11-14-2003, 09:34 PM
Banned
I used to use Curil k-2, But now 1104 is my sealant of choice thanks to Otto who showed me how well it works. Clean all the sealing surfaces with acetone or MEK.Steve
Old 11-14-2003, 09:38 PM
Where can you buy "Top Bond 1104"?????????? Not sure my FLAPS has it.
Ken
Anything worth doing is worth doing in excess
Every silver lining has a cloud
Assume Nothing
Old 11-15-2003, 09:23 AM
MXMARK's Avatar
Ken, you may be talking about "ThreeBond 1104" in a yellow package available at most motorcycle shops.
Steve is this the stuff? Mark
1985 Targa Carrera
1972 914 2.5L four, side shift
1987 944
2005 Husqvarna CR125
1980 YZ125G
Old 11-15-2003, 09:31 AM
Banned
The Yami dealer Yamabond is the same stuff.Steve
Thanks,
Ken
Assume Nothing
Old 11-15-2003, 09:36 AM
Banned
YEP thats it. Steve
MXMARK's Avatar
Steve is it Yamabond 4 (semi-drying) Yamaha # ACC-YAMAB-ON-D4
Mark
1985 Targa Carrera
1987 944
1980 YZ125G
Old 11-15-2003, 09:37 AM
MXMARK's Avatar
Steve,sorry I took to long to post Thank you Mark
1985 Targa Carrera
1987 944
1980 YZ125G
Old 11-15-2003, 09:38 AM
Banned
It works great,Mark whats the specs on your 2.5? Steve
Old 11-15-2003, 09:41 AM
MXMARK's Avatar
Steve it has been about 4 yr since the motor was done. It started as a 1.7l that was made into a 1.9l then a 2.2l est now it is close to 2.5 l in the 1.7 cases. Big crank counter weighted, Big cylinders maybe 103 or 105 big valves. Another engine builder in Orange County helped me and I am Very happy. You also helped me get some parts for the car. I will try to get the specs for you. Sorry I feel silly for not having all of the answers in my head. New baby will do that. I will call you during the week. Have a good weekend Mark
1985 Targa Carrera
1987 944
1980 YZ125G
Old 11-15-2003, 09:56 AM
415pb's Avatar
Thanks to all, I picked up a tube of Threebond 1104 from a Harley mechanic this morning.....
Thanks,
Rod
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 11-15-2003, 06:36 PM
Banned
Alfred1's Avatar
I always had the feeling that the cases should be one piece ... maybe something like this http://www.pauter.com/super_pro.htm .
Old 11-15-2003, 06:47 PM
415pb's Avatar
Now those engines are nice..........$$$$$
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 11-15-2003, 08:52 PM
