Dbelleperc's Avatar
Symptoms of a failing or failed Master Cylinder
The 914 that I will be picking up at the end of this month has a brake problem. After about 10 minutes of driving the pedel goes stright to the floor without any pressure and you have to pump the pedel about 5-7 times before pressure comes back. Does anyone know what the problem could be? Air in the system, need to rebuilt calipers, or something else? Thanks.
70' Porsche 914
73' Porsche 914
03' Mini Cooper S
03' Volkswagen Passat GLX B5.5 4-Motion
Benjamin Miles Keaton (ben, lj) - RIP June 2nd, 2005
Old 12-02-2003, 04:07 AM
M. Hendrix's Avatar
After driving... hmm.. I thing you have one condition, compounded with another.
I think your soft brake lines are shedding their liners, and I think you may have some air in there, but it won't matter if the liners are separating.
When the MC is bad, the pedal refuses to return properly, and the action all comes on (or not) in a very short part of the throw.
I've been wrong before.
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 12-02-2003, 04:56 AM
Dbelleperc's Avatar
I forgot to add in the earlier post. Before the pressure is in the peddle I have to pump the peddle to the floor and bring the peddel up by putting my toes behind the peddle and pulling it towards myself. Then I will have pressure in the peddle and brakes. But once I release the brakes I have to repeat the process over again.
70' Porsche 914
73' Porsche 914
03' Mini Cooper S
Old 12-02-2003, 05:27 AM
M. Hendrix's Avatar
I think your MC is bad.
M
Old 12-02-2003, 06:18 AM
John Rogers's Avatar
If it were me, I sure would not drive it home!!
Old 12-02-2003, 07:05 AM
914 Geek
Sounds like at least the MC is bad. Very possibly more. Check for rust around the pedal cluster--often a bad MC will leak brake fluid into the car, which will then eat the paint off the floorpan around the cluster. Rust, rust, rust....
You could easily have other problems with the brake system as well.
--DD
Old 12-02-2003, 08:45 AM
Dbelleperc's Avatar
There is no rust on the car. But the brake fluid stays constant. Checked the reservoir every week.
And John I am shipping the car myself. I was just thinking what I may have to do when I bring the car back to San Diego. Anyway I plan to replace the rotors, pads, lines, and maybe rebuilt the calipers.
70' Porsche 914
73' Porsche 914
03' Mini Cooper S
Old 12-02-2003, 09:30 AM
Rouser's Avatar
Send a message via ICQ to Rouser Send a message via AIM to Rouser
Chances are, the (original, plastic) pedal cluster assembly bushings are all swollen/deteriorated from brake fluid getting past a wornout MC. Be ready to see fluid all over the cluster assembly upon inspection.
Also, save yourself the headache of going roundy-round troubleshooting or "bleeding out" a soft/spongy pedal by replacing the flex-lines to each caliper.
I've seen this issue arise over-and-over. Remember, the brakes just aren't the place to trim your 914 budget to save up for that used Saratoga Top on eBay, or those phat 18" rims & tires. So far, you look like you're heading down the right road, figuratively.
Rouser!
Old 12-02-2003, 02:05 PM
Dbelleperc's Avatar
I'll take that as a complement, I am getting this 914 from my uncles son in Dallas and he got the car from my uncle. I plan on doing a complete restoration and have the car running, and ready to go.
The car will be a garage queen only coming out to get cleaned or to have some fun on the weekend.
70' Porsche 914
73' Porsche 914
03' Mini Cooper S
Old 12-02-2003, 05:12 PM
