Suggestions Please
Little by little I am getting close to fixing the rust issues on my car. I have the floor cut out to replace it but I need to get all the surface rust out of the hidden areas before the new one goes in. I am having a hard time getting in between the two lower pieces of the firewall. There is only about a 2 inch separation, not to mention all the various tubes passing through, so I can't get a wire wheel in there. I have been using a small wire brush but I'd like to get it cleaner than I am currently able to. Does anyone know of an easier and more thorough way to get in here?
Old 12-06-2003, 11:53 AM
You already know what it would take to get close to total rust-free bare metal in those areas - media blasting. About all you can do otherwise is vacuum out all the loose dirt and rust and apply a rust converter. I've taped a piece of poly tubing to a shop vac and worked that around inside to suck out the loose stuff. Then take a garden sprayer to spray a rust converter like Rust Mort to convert and stabilize surface rust. You could get some extra protection if you could get some rust proofing paint like POR15 inside. I've done this by working in a small foam roller cover on plastic tubing.
Old 12-06-2003, 06:19 PM
grind weld build
sean_V8_914's Avatar
Ospho or Jasco.
convert teh iron oxide to iron phosphate
avialable under $5 at Home depot, home base, home thingy...
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 12-06-2003, 06:48 PM
The Jasco 'Prep & Primer' looks like the same stuff as the SEM Products Rust Mort sold at auto paint suppliers. If it's only $5/quart then that's the way to go.
Old 12-06-2003, 07:18 PM
grind weld build
POR-15 metal ready uses the same basic chemistry also but they added some zinc. main ingredient is phospheric acid
73 Orange, CS #601
Trek 6500+
Sean M!
Old 12-06-2003, 08:47 PM
914 Geek
"Naval Jelly" is another term that may help you to find a "generic" equivalent.
--DD
Old 12-07-2003, 01:22 AM
Ospho is great. Only problem with it though is the black residue (iron phosphate mentioned above) it leaves. It can be as difficult to remove as the rust. I have noticed some people leave it there in areas like you are describing that will never be seen by anyone else.
Old 12-08-2003, 09:06 AM
grind weld build
POr 15 over the top of it. the key is to stop the iron oxidation
73 Orange, CS #601
Trek 6500+
Sean M!
Old 12-08-2003, 11:09 AM
Yes, that's the purpose of the converters - change the rust to a stable coating. If you want to remove the rust then that's where Naval Jelly or removers come in. But it's almost impossible to get it completely out of areas like the tunnel or longs. Just convert it and leave it, and take steps to prevent water from being trapped in those areas.
Old 12-08-2003, 11:45 AM
mike95125's Avatar
John 9:14, the intent of ospho is to leave the black iron phosphate on as a protectant. You can paint over it and it will not further exfoliate/oxidize.
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 12-08-2003, 01:13 PM
M. Hendrix's Avatar
yeah yeah!
You need to surface the area first with emory cloth, a wire brush... ect.. Ospho, then just get that area hot, dry it out, and hit it with some primer..
Sticks like you wouldn't believe!
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 12-08-2003, 01:59 PM
