Oil light issue !!!!!
Just got my teener back from the paint and body shop, and driving it home I noticed that the oil (green) light was on. I immediately pulled over to the side of the freeway. Checked the oil level......All was ok and no leaks. After I fired the engine back up, the light went out.then slowly came back on in the next 30 seconds once RPMs got up to freeway speed. During the drive, I would get up to speed, put her in neutral, and turn off the engine for a few seconds then start it back up. Each time the light would go out for a few seconds then slowly come back on. Could this be a flaky sensor?????? PLEASE????? I hope so!!
Old 12-29-2003, 12:41 PM
Joe Sharp's Avatar
If you were on the freeway and your motor isnt junk just change the oil light sending unit.
Joe
http://www.clubnarp.com/
My mechanical ability seems to be directly related to my ability to withstand pain.
He who plays with the most toys wins.
Old 12-29-2003, 12:47 PM
calbrat's Avatar
Sensor is probably bad.
Funny thing is all those lights seem to work well in Tahoe in my car but never again since I drove it back.
Old 12-29-2003, 03:47 PM
so....does this just sound like a sending unit issue???
norustscott's Avatar
check the wire for a bad connector or it is simply loose on the sendor unit
and or replace the sender. very cheap...
Scott
1982 911 SC
1962 sunroof bug
1991 WE Vanagon CARAT WRX conversion
Old 12-29-2003, 05:09 PM
Ron Meier's Avatar
Well, if you want bad news, it could be a relief valve spring that has detensioned with time and heat.
GAWD, I love being the Ogre! Now I'm off to mess up another dream.
"Inventor - Blue Flame 914 Seat Heater"
"Yellow Rusty Cars Are Faster"
_____________________________
'70 2.5 (I'll never finish it - Somewhere over the rainbow.....,)
'73 2.0 (Just Not The Same)
'74 2.0 (Heartless & Lungless)
Old 12-29-2003, 09:46 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
explain that last one, Ron.
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 12-30-2003, 05:27 AM
Ron Meier's Avatar
Since relief valves are nothing but a piston with a spring behind it and metal can be stressed by heat and continued flexing (compression and extension), over a period of time the spring can lose it rated tension, allowing the piston to retract under less pressure .
Secondly, since this is a piston moving in a bore, it can get galled and stick in an open position. When the pressure is relieved, it can possibly unstick and go back into position.
This is why your rear springs, torsion bars, etc - lose their ability to control a cars weight.
Anybody else care to add or tell me I'm full of crap?
Old 12-30-2003, 09:39 AM
canna change law physics
red-beard's Avatar
I say you're full of crap, but not on this issue
James
Red-beard for President, 2020
Old 12-30-2003, 11:42 AM
Ron Meier's Avatar
My eyes ain't brown; they're blue so I'm a quart low - Na Na Na Na Na
Old 12-30-2003, 12:55 PM
