Wierd Electrical Problem
Had my six at the shop to hook the wiring back up from the console gages.
Everything works now except when I turn on the headlights, the tach drops about 1,000 rpm.
Anyone have any thoughts - or does this mean my redline at night is suddenly 1,000 rpms higher?
Barry
Barry Schwartz
1999 996 Cabriolet [pastel yellow with brick interior]
2004 Mercedes E55 AMG
2005 Volvo V70R
2003 Volvo S-60 turbo [high maintenance daughter's car]
1974 Triumph TR6
3 cats, 1 dog and 1 kayak
Old 04-19-2004, 09:59 AM
Check the +12V and GND wires to the tach that they are the correct. Something must be miswired where the voltage drop from the headlights is affecting the tach voltage.
Old 04-19-2004, 10:31 AM
Guy:
Thanks for the insight. It always helps to know where to start before you lay on your back and get up inside the dash.
Barry
Barry Schwartz
2005 Volvo V70R
1974 Triumph TR6
Old 04-19-2004, 10:35 AM
914 Geek
Also check fuse #9. Take it out and inspect it. Either clean up the ends with a wire brush, or just s**tcan it and put a new shiny one in. Clean up the "arms" that hold it, too.
--DD
Old 04-19-2004, 03:51 PM
Thanks Dave for the suggestion.
Barry
Barry Schwartz
2005 Volvo V70R
1974 Triumph TR6
Old 04-20-2004, 05:12 AM
philinjax's Avatar
Barry,
This is my shot in the dark guess; If the rpm only drops when the light switch is on and low beams are sellected, the WH/BL wire (for the high beam indicator light) is interchanged with the RD/WH wire (which supplies power to the tach.). Both of these wiring connections are on the bottom rear of the tach.
Good luck,
Phil
Old 04-20-2004, 11:57 AM
Phil:
I'll check that connection. It is an easy one for me to reach without a lot of contortions.
Thanks.
Barry
Barry Schwartz
2005 Volvo V70R
1974 Triumph TR6
Old 04-20-2004, 01:29 PM
