Wierd Electrical Problem
Had my six at the shop to hook the wiring back up from the console gages.
Everything works now except when I turn on the headlights, the tach drops about 1,000 rpm. Anyone have any thoughts - or does this mean my redline at night is suddenly 1,000 rpms higher? Thanks Barry
Barry Schwartz 1999 996 Cabriolet [pastel yellow with brick interior] 2004 Mercedes E55 AMG 2005 Volvo V70R 2003 Volvo S-60 turbo [high maintenance daughter's car] 1974 Triumph TR6 3 cats, 1 dog and 1 kayak |
Check the +12V and GND wires to the tach that they are the correct. Something must be miswired where the voltage drop from the headlights is affecting the tach voltage.
Guy:
Thanks for the insight. It always helps to know where to start before you lay on your back and get up inside the dash. Barry
914 Geek
Also check fuse #9. Take it out and inspect it. Either clean up the ends with a wire brush, or just s**tcan it and put a new shiny one in. Clean up the "arms" that hold it, too.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Thanks Dave for the suggestion.
Barry
Barry,
This is my shot in the dark guess; If the rpm only drops when the light switch is on and low beams are sellected, the WH/BL wire (for the high beam indicator light) is interchanged with the RD/WH wire (which supplies power to the tach.). Both of these wiring connections are on the bottom rear of the tach. Good luck, Phil |
Phil:
I'll check that connection. It is an easy one for me to reach without a lot of contortions. Thanks. Barry
