transmission fluid advice
Hi,
I recently rebuilt the trans, please let me know which fluid to use ? let me know regards |
canna change law physics
80W90 Gear Oil.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Red-Beard, do you believe there is a SIGNIFICANT difference between standare 80-90W gear oil vs the synthetic vs Swepco?
I appreciate your experienced opinion. L. McC |
I can't find any real information that Swepco is anything but 90W gear oil.
914 Geek
With nifty blue dye in it. And probably (not sure!) their own particular additive package.
We recommend it, but then again we do sell it! Mechanics that I trust have very specifically recommended it to me, so that's what I have gone with. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Yeah, and at $40/gal it has substantial margin...
I use Coastal at $6.99/gal.
Ornery Bastard
Personally, I like Mobil 1 synthetic gear oil. It definitely made a difference in shift quality in my 924S and the Mobil 1 synthetic gear oil is much less expensive than Swepco or RedLine while providing more than enough benefit for street applications.
While Swepco and RedLine are indeed "better", the amount by which they are better is not enough to justify their extra price. My personal opinion is that Mobil 1 sits at a sweet spot in the cost/reward payoff curve. Aaron
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
OCD project capitan
Aaron, so do you use the synthetic in your 914 gear box? Last time i tried to use synthetic i was forced to become a double-clutch pro. Now as re-beard said, the Swepco is more expensive, but i don't take my trans apart all the often anyways...
Don Welch '73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper. |
Ornery Bastard
I switched over in the 924S because I was getting 2nd gear "lock-out" on cold mornings in the middle of winter. I will say that if using synthetic causes your synchros to stop working effectively, then there was a pre-existing condition in the transmission that was almost certainly being masked by very, very dirty gear oil. before synthetic was put in. Aaron
Decent fresh gear oil is the best gear oil.
I have to agree with Aaron. Putting Mobil 1 in my gearbox eliminated 90% of the shifting stiffness I was experiencing in a fresh, professionally rebuilt tranny.
'00 Volvo S80 '96 Jeep Cherokee '94 Toyota Camry deceased '72 1.7 deceased '75 1.8 '41 HD Knucklehead (rebuilding basketcase into chopper) '74 1.8 (Ravenna green and drivers still don't see me!) |
I used Mobil 1 in my 914/6 box. I had no shifting issues. I agree. If you are having shifting issues, get the tranny fixed. Oil will not fix the tranny.
75' 2.0 w Ljet "I like the way she doesn't move in the curve's... and then she let's go!" |
914 Geek
But to each their own. --DD
OCD project capitan
Back when i did use the synthetic, the trans was on its way to needing new syncros. However, everytime i've driven a car with a 901 gear box running sythetic, double clutching was better because the syncros were too slippery, there was no bite for the dog teeth on the selector rings. Once i drained the synthetic out and replaced with swepco, it was like night and day. Granted, at the time it still needed a rebuild, i comfortly got several thousand miles out of it before overhauling it.
Ok...
I am kind of new at the whole transmission deal. I had to get a new engine for my 914 and i also took the rear off the end of my transmission to check my first gear. Now I'm trying to figure out how to replace all of the lost fluid. Is there a dipstick anywhere on the tranny? How would i go about gauging my level of tranny fluid and then replacing it?
Thanks- Corey |
Two big allen-head screw things (maybe 22MM?) on the right rear side of the transaxle for draining and filling. Do remove the fill plug before the drain plug, so will be able to refill without tipping the car on it's side!
OCD project capitan
Cory, they are 17mm hex (allen) sockets. You'll probably need to by the tool (a 1/4" socket 17mm hex) to get the job done (i tried to make a tool with a 17mm bolt, nuts and a wrench, but sometimes those suckers are in there tight). With the trans on level gound (either on the work bench or in the car), make sure the bottom plug is secured in the drain hole, then start filling the trans with new oil. I do this with a oil hand pump which can be purchased at any autoparts store. Stop filling when the oil starts flowing out the hole. Its that simple.
Cheers, Don.
Don Welch '73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper. Last edited by BigD9146gt; 10-13-2004 at 12:59 PM.. |
haha thanks, i'll go do that now then.
The only place I could find the 17mm 1/4 drive socket localy was a Snap On truck. Met the guy on the side of the road. $12 - Keep the socket in your glove box, because you will never need it for anything else.
