Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Upright cooling
Here is the cooling system I am building for my 914.
This is use Two Type4 Fans, Two 36hp Shrouds and Two Oil Coolers.
Each 36hp shroud cools two cylinders and an oil cooler.
I am putting a 2715cc together and this should cool it nicely.
And yes it will fit in a 914.
Old 12-03-2004, 10:38 AM
norustscott's Avatar
Very interesting...where is the second oil cooler...is it a stock vw cooler...late model type one?
Scott
1982 911 SC
1962 sunroof bug
1991 WE Vanagon CARAT WRX conversion
Old 12-03-2004, 12:54 PM
oh and is it in the shroud?
Scott
1982 911 SC
1962 sunroof bug
Banned
Yes it is mounted in the doghouse of the shroud. Photo is of the mock on a spare case.
Old 12-03-2004, 01:16 PM
Acox914's Avatar
Send a message via AIM to Acox914
how do you put oil in it now? mounted the alternator on top of the oil filler....
-Aaron
"60% of the time, it works every time"
Old 12-03-2004, 07:41 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
oil cooler looks like it wont get enough airflow..
Old 12-03-2004, 09:02 PM
Banned
There is a hole in the plate that the Altenator is mounted on. It is just to the left of the Altenator.
This is where the filler neck will attach.
Old 12-03-2004, 09:06 PM
Banned
The air flow should be sufficent. There are two coolers.
Old 12-03-2004, 09:08 PM
Not how I'd do it personally. I wouldnt trust the cooling of my oil on cheap heater hose..
I'd like to see Jake's thoughts one this one...
Old 12-03-2004, 09:11 PM
Banned
Actually that peice will be a Steel tube not the Aluminim foil tube. That just to mock up.
Old 12-03-2004, 09:20 PM
still seems inadequate.... I certianly wouldnt have a plate covering 60%of my oil cooler....
Old 12-03-2004, 09:26 PM
Banned
It sitting low When in the proper spot the Chamber has about as much volume the size of the cooler. The lower edge of the duct is mounted jus below the top edge of the cooler.
Old 12-03-2004, 09:35 PM
ruddyboys's Avatar
It looks rather tall, will it fit in the engine bay with lid closed.
74 LE "Bumblebee"
03 Jetta Wagon
Old 12-04-2004, 08:38 AM
grind weld build
sean_V8_914's Avatar
I like to see intrepid guys trying new things. some people theorize their lives away and other just do it. good job. cant wait to hear about the results!
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 12-04-2004, 12:41 PM
Banned
From the top of the case to the top of the fan Shroud is 12.5 inches.
Old 12-04-2004, 02:30 PM
grind weld build
how big an engine can teh stock front mounted fan system handle?
73 Orange, CS #601
Trek 6500+
Sean M!
Old 12-04-2004, 06:33 PM
With the fan turned that direction, where will it be obtaining it's air from??
When the backing plate is installed the intake will be suffocated..
With all that plenum volume on the left side of the shroud you are gonna have one hell of a time directing the air on that side down to the cylinders. Thats one of the issues that I had with the Type I DTM in the beginning.
The other challenge is keeping that fan together at high RPM with any overdrive at all. Joe made a Hybrid fan for the DTM 15 years ago and I have tested it airflow wise and it didn't work worth a hoot. The last one I tested scattered the fan with a 1.24:1 drive ratio with a crank speed of 7,000 RPM.
The stock TIV fan cavitates at 4400 RPM a great deal, be ready to machine about one half of those fins off to get around this..
Glad to see you trying it, be ready for a year or so of trial and error to even get it close to being efficient.
Good luck- You'll be needing it!
Jake Raby
Owner, Raby's Aircooled Technology
www.aircooledtechnology.com
www.massivetype4.com
Old 12-05-2004, 05:36 AM
Banned
The fans will turn at crank speed.
The air is pulled in from the front to cool cylinders 2&4 and the rear to cool 1&3 .
It has two air inlets like a Carrera 4 cam shroud.
The volume of the 36 hp shroud is still stock, there is a spacer between the two shrouds of about 1..5 inches.
Old 12-05-2004, 09:47 AM
Zeke's Avatar
You go, Steve. If you can find 4 older go kart head temp gauges, the single window type, you might get them on the cheap. You can prove your unit's worth with them.
Old 12-05-2004, 05:06 PM
Member w/ Title Problems
Jason Porter's Avatar
FWIW, if I was building a 2.7L Type 4, I would use a proven cooling system, not experiment. With that kind of displacement, a DTM wouldn't even be enough if it's slightly out of tune.
2023 Ford F-150 Platinum 5.0 Coyote FX4
2019 Toyota Sienna XLE AWD
Metal Building Erector, Recovering Porsche Guy
Old 12-06-2004, 01:51 PM
