Found My V-8 914 Project
I have been looking one for over a year now and stumbled on a post on the Renegade Hybrid site in early February. After a lot of emails, searching for a good escrow co. and transporter the wait is almost over. Its a 70, 914, Edelbrock heads and fuel injection, on a fresh 350 rebuild hooked up to a Renegade converted 930 transmission. All 930 suspension and brakes. Just need to finish up some lose ends, trans linkage, wire up fuel system, install the new calipers etc. Hope to have it on the road in a couple of months. Here's some pictures.
Well, found one and its coming to Ca.
70, 914, V8, 930 trans.
V8 914
License Plate "A go cart"
Another pic
Old 06-10-2005, 10:21 PM
grind weld build
sean_V8_914's Avatar
yummy! have fun
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 06-11-2005, 11:00 AM
914helo's Avatar
Should be a blast! Good luck.
Kent
'73 914 - Suby 3.3L conversion
'99 996 - For sale ($22K)
Old 06-11-2005, 03:08 PM
Priced-out of Porsches.
mmastro's Avatar
All 930 suspension and brakes?
I'd love to see how they did the 930 calipers on the rear of your 914. I'm about to do the very same thing to my 75 V8. All 78 930 suspension/brakes.
Thanks,
Mike
SoCal
Old 06-29-2005, 08:02 PM
Thanks,
The front calipers are on and the rear are still in a box. The brakes may be just 911 I cant see them being turbo units but I am new to Porsche. I will try to get a picture up soon.
Old 06-29-2005, 09:47 PM
mike mueller's Avatar
Thanks,
For the rear, a new bracket is welded to the bearing housing with the correct spacing and offset...I'll try and take pictures of the setup I have at home.
'73 914, 1.7, with Boxster transmission in the future?
Old 06-30-2005, 01:23 PM
mmastro's Avatar
Cool! Thanks
Mike
SoCal
Old 06-30-2005, 06:38 PM
byndbad914's Avatar
don't know if it helps you, but check out vehicle craft online. I sent my 930 rears there and had them machined to bolt up to the stock trailing arms and the setup uses a stock turbo rotor for the rear. It is around $400 if I remember correctly. In the pic above with a closer shot of the front wheel, the little bit of caliper I see is not the 78-89 930 Brembo - maybe it has the early 77-78 930 brakes which are quite different.
I have heard of the weld-on bracket too, I suspect it is "six in one hand, half dozen in the other". Just another option... obviously if I mess up a caliper, I would have to have another machined to bolt on, but I haven't ever experienced destroying a caliper so much I couldn't rebuild it...
I don't have any really good shots of the work, but you can check out various parts of my site to see what the later Brembos look like on my 914 v8 project.
www.geocities.com/byndbad914
Tim
www.negativereinforcementracing.com
1972 914 1.7L turned FW190-V8
353cube 525HP SBC with Mendeola S4 transaxle
Old 07-12-2005, 06:34 PM
mmastro's Avatar
The 75-77 930 came with the S calipers up front and M's in the rear. The 78-89 930 came with the 917 type calipers all the way around.
I'd be interested in the vehicle craft rear set up for the 917 type caliper on a stock 930 rear rotor, that seems like the way to go (no adapter/weld-on piece).
Cheers,
Mike
SoCal
Old 07-13-2005, 02:05 PM
