Prolly should explain more details. I have one side shift and one tail shift spares. the tail shift has good bearings. The side shift is giving up the ZD gear and rear cover housing and shifter This way I have all the working of a new side shift trans. the beat one came from Scott Thatchers porscharu.
Yup the pic above looks just like what I got last night.
Karl I think we need to get together this weekend as is it going to be hot and no races.
Old 06-22-2005, 06:36 AM
914 Geek
As DIY'ers, we have the luxury of being able to spend extra time checking to see if the problem is caused by something low cost (even if the probability is also low). I feel it's worth ruling the linkage out. With Otto's years of experience, he is almost certainly right, but the transmission overhaul is not for the faint of heart, as has been mentioned.
To answer "computers4kids" question about the clutch tube: The tube will move around in the center tunnel, and it can interfere with the movement of the gear shift lever. That will give you problems going into 4th and 5th gear. In addition, often the clutch will not stay adjusted because of the movement of the tube. That will give you problems going into 1st/reverse--or at least a nice "crunch" when you do so!
Unlikely to be your problem. But then, you can take the carpet off the center tunnel and check in there with a flashlight and a mirror or two, just to be sure...
--DD
Old 06-22-2005, 10:04 AM
Otto's Avatar
4th.
All you gotta do is pull the drain plug and see what kinda stuff is on it. If the oil that came out of the transmission is kinda brassey looking, you need to replace the ID plate bearings. Thanks, Dave, positive feedback will bring 40 years of knowledge back to the board.
Racing Porsche for over 30 years.
http://www.OttosVenice.com
Check out the Porsche Owners Club Track event Videos
Old 06-22-2005, 03:33 PM
