djs djs is offline
Swivel feet adjusters...
I've seen two different designs for swivel feet adjusters. One design has the socket integral with the adjuster screw, and a swiveling ball with machined surface contacts the valve stem.
The other design has the ball integral with the adjuster screw, and a socket with machined surface contacts the valve stem. Tom Wilson's VW engine book shows this latter type, and I assume this to be the VW-approved design. He specifies using the VW-approved type only, because it is not unduly hard and thus will not damage the valve stems like some other hardened swivel adjusters might.
Questions:
1) Can anyone confirm which swivel feet adjusters are the best ones to use?
2) If the "Tom Wilson" specified design is the one, do I still get these from the dealer, or are they available aftermarket?
I'm planning to use 8mm rockers with solid spacers, as has been suggested.
Thanks in advance!
Dan
Old 12-26-2000, 12:40 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
The ball style can roll when you adjust the clearance,I only use the Big Foot style.Steve
Old 12-26-2000, 03:26 PM
norustscott's Avatar
Steve is right. You have to be careful with the valve adjustment as the ball can rotate in the socket. I have used the ball type for ten years. They work fine. However, this was on a type one drag motor. rather easy access compared to a 914. Stick with the big foot type..good luck.
Old 12-26-2000, 07:45 PM
