front wheel choice flared 914 and engine options
Hi everyone
At the moment I am trying to work on my hobby whenever I have a spare moment,
This project car is a '75 2.0 w/ GT flares and frozen engine. It has the hubs drilled out to five studs. It came without wheels. I had to take of the studs and put 4x130wheels on it just to bring it home. Those wheel wells are big!! need something big to fill it with. Luckiliy on ebay I found two cheap big tires, 245/60/15, I know they are big and not super high performance given the 60 series but I thought what the heck. Problem was it took me a lot of time to find the right wheel to match. Finally this weekend I bought two replica fuchs wheels 15x8 w/ 4 7/8 backspacing, that match perfectly. Looks very impressive.
Now the question, What to do for the front. For now as mentioned it has the standard 5.5 wheel w/ standard backspacing, I believe 4 1/2". There is about 3" of space between the tire and the fender lip. At first I thought the 15x7 would be the way to go, but thinking about it , the fuchs wheels I can get (15x7) also have 5" backspacing, that means that the wheel is .5" more inwards and only sticks an inch more outwards compared to the stock wheel, that leaves me still w/ 2" gap.
Of course one can use spacers, but 1.5" of spacers would be pushing it. And to go with 15x8 in the front you also need a lot of tire, I am not sure if that is desirable, performance/handling wise. What would be my options?
Another topic is the engine, the engine in it is stuck. .Previous owner left car outside without rain drain under engine lid, and without airfilter and throttle body, You can imagine what that would do over time. I was thinking that the way the car looks in this GT outfit, would demand a little more powerful engine ( I can rebuild the engine, but I know that this setup (my other 914 which is my daily driver has a 2.0 w/ dual 40 dellorto), although I love it, is not exactly super performance. I do not have the resources to go to a porsche flat 6, although I lreally like this engine, ( we also need a new roof etc.. )
So the question is , suppose one would consider a different engine choice ( not politically correct, but tempting), what are the rules regarding California smog. My car is built in 1974 and is a 1975 model, I checked the DMV website and I am fine there (smog exempt). I should mention that since this car has been out of the loop for a long time the vin nr is no longer recognized. According to the previous owner I must go to dmv and have them check the vin number when i register. This means that they will look at the car. And will notice any obvious engine change. Being smog exempt, do I have to stay with a certain engine year to be safe, I would think that if I put a newer engine in the car, the newer engine is not smog exempt and dmv would require me to start smogging based on the engine year, which ofcourse I want to stay out of. On the other hand an older engine might not be accepted by DMV because you are putting an engine in it with probably worse smog quality than the year of the car. Am I thinking right, Seems to me the easiest way is to stay with the same year 1975. But that might not be easy finding the right engine for that particular year.
Anyway, I see so many people w/ smog exempt cars with engine conversion using modern engines that I begin to think that I have it completely wrong.
Anyone who can shed some light on this issue please tell me how it works. Any input would be greatly appreciated.
Raimond
Old 09-20-2005, 09:27 PM
SirAndy's Avatar
Re: front wheel choice flared 914 and engine options
Originally posted by razwiers
Anyway
currently, on the street, i run 7" cookie cutters with 225/50 tires.
in the front i use a 1 1/4" spacer and in the back a 1 1/2" spacer.
they fill out the flare nicely.
i also have a set of 8"/9" ronal alloys that i will eventually run.
it's going to be 245/45 in the front and 285/40 in the rear.
which is what the factory used to run on the 914/6 GTs as well ...
for the track i have a set of 7" cookie cutters with 9" goodyear slicks ...
Andy
>> 1970, 914-6, 3.6L (Conversion)
>> 1970, 914-6, #374 (Original)
>> 1975/73, 914 Limo (Custom)
Old 09-20-2005, 09:51 PM
Hi Andy. Thank for your reply,
What length studs are you using to accomodate the 1 1/4 spacer + wheel? At the moment the hubs I have just have the 5x 130 threads bored out, but do not have the studs locked in, I was thinking to use the vw style alloy length studs for now, but not sure if that is wise.
Did you ever experience problems using this thickness spacers or does it work fine?
Old 09-20-2005, 10:08 PM
never make your wheel choise on the basis of a set of cheap tires.
k
here? not so much i think. high five!!!
Old 09-21-2005, 04:39 AM
I knew I was engineering backwards, but in the end I ended up with the wheels that I always wanted, what size do you think I could use for the front? What about the dmv issue?
Raimond
Old 09-21-2005, 08:54 AM
SirAndy's Avatar
i'm running 100mm studs in the rear which turned out to be overkill.
in the front i have 72mm studs which work fine for my two different offset wheels (track and street) and they would have been enough in the rear as well ...
hope this helps!
Andy
Old 09-21-2005, 09:49 AM
Acox914's Avatar
Send a message via AIM to Acox914
like andy said - you can run 245's up front.....
and dont limit yourself to 7"/8" wheels...
im running those under nearly stock fenders....
put 8's up front and get some 9's or 10's for the rear....
-Aaron
"60% of the time, it works every time"
Old 09-21-2005, 09:59 AM
Thanks guys for your input.
Cheers
Old 09-21-2005, 04:54 PM
