Drain Hole In Engine Compartment(Driver Side)
On the 1973 914 2.0 L is there a drain hole for water? I am getting water into passenger cabin from the engine compartment release cable. I noticed this after a very heavy down pour.
LW
Old 01-16-2001, 11:19 AM
There are actually two drains located in the forward part of the engine compartment, below the two spouts for the engine cover plastic rain shelf. If you look down in those areas, there will be two spots that will hold water if the drain clogs (which it will do). The drain hole has a rubber piece in it, that sticks outward towards the side of the car. If you feel under the car, up abouve the swing arm mounts, you should find it. It can be popped out to clean, but be ready for an arm of water :-).
Old 01-16-2001, 12:45 PM
Conrad W Peden's Avatar
Same symptoms here.
Cause: engine lid seal not sealing + stupid sound pad in engine compartment = hole rusted through firewall just above the cable.
Here is a pic of mine. http://members.rennlist.com/a914lover/page5-4.htm
CWP/VIR
72 914 L20E in rusto.
73 914 L20E 2.0L in resto.
Old 01-16-2001, 12:53 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
I agree with Conrad. The Dreaded Rust,you should check this out promply, as Neil Young Sang "Rust Never Sleeps" .Steve www.914underground.com
[This message has been edited by SteveStromberg (edited 01-17-2001).]
Old 01-17-2001, 06:01 PM
