Hello,
I've bought a new (old) rear valance for my car and there is something strange. All the holes are in good position but at the extremity of the valance (beyound "les ailes"), the steel goes up.... My explanation is not so good, so, I give you a picture : What have I to do with this (where it's indiquate in black), is it normal (so maybe need a rubber between the rear valance and "les ailes" or have I to cut it ? Thanks for help.
Valery 914 2.O 1973 |
the front hole requires a spacer 5-6 mm tall. factory part is black plastic
hope this helps |
Thanks to you 914/6. Is anybody says me what's the part number of this plastic 5-6 mm ? So, I can order two.
Underneath, a picture with the rear valance on the car : Waiting for part number. Regards, Valery
914-559-127-11 spacer
Big Thanks to you
Valery: I used a short length of hose.
Joe
http://www.clubnarp.com/ My mechanical ability seems to be directly related to my ability to withstand pain. He who plays with the most toys wins. |
Thanks Joe. I've not still ordered for the parts. The hose is a good idea but I would like to make the same size that the original. So, what's the length and wich diameter ?
Thanks.
Control Group
I used a stack of rubber washers, perhaps 5 mm thick
This has everything you want to knowValence Thread
She was the kindest person I ever met Last edited by Tobra; 04-18-2006 at 07:50 AM.. |
