Send a message via AIM to Baloo914
Question hotter spark plugs
Just wondering what benefit there is in running a "hotter" spark plug. What is actually different in the makeup of the spark plug?? What is the reason for not wanting a hotter or colder spark plug??
TIA
Old 04-13-2001, 02:31 PM
John Rogers's Avatar
Post
The heat of 914 spark plugs is generally a good all around plug for everyday use and even autocrossing. Simply put, hotter plugs burn hotter and colder plugs burn colder which relate to the amount of heat transfered from the plug to the head. High compression full throttle race engines will a a slightly colder plug than a comparitive street engine since hot plugs can cause preignition, etc. Check out the two links below to get some more info on plugs. Good luck.
http://www.clubplug.net/cross.html
http://www.softcom.net/users/magers/html/ngk_lookup.html
Old 04-13-2001, 05:12 PM
