iamchappy's Avatar
How much fun is this gunna be! turbo engine done
Here are some pictures of my newly built 3.12 long stroke turbo engine.
built similar to the 935 IMSA engines that made around 700hp.
Mine is going to be much tamer, but should still crank out over 400hp without working to hard.
Looks like my 914 is getting closer and closer to it's completion.
Many thanks to Henry Schmidt from SuperTec for his guidance and taking the time to talk to me many many times over the phone about it, and to Matt and Bob Johnson from Johnson MotorSports for building the monster for me.
What do you think? Is this going to be fun or what!
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 08-30-2006, 06:17 PM
Looks like K-Jet?
I need detail pics of the important pieces. :drooley:
Try to keep the tires connected to the ground. :lol:
Old 08-30-2006, 08:26 PM
Acox914's Avatar
Send a message via AIM to Acox914
turbo CIS :chubby:
-Aaron
"60% of the time, it works every time"
Old 08-30-2006, 08:33 PM
iamchappy's Avatar
The engine started as a 3.0 79 SC engine, It now has the 92 turbo 3.3 piston and cylinders in it modified rod ends for wrist pin enlargement and longer stroke, turbo oil pump, 86 turbo 930 intake ported to the big 79 SC intake heads, a Euro fuel Distributor with matched flowed injectors, SuperTec twin plug distributor and head studs, ARP rod bolts, racing valve springs, full rebuild with new valves. Will be firing a micro fueler at 10lbs for a rich afr at 1 bar boost with a 7.5 to1 compression. 1070 CFM intercooler, k27 turbocharger, tial wastgate and a tial bov.
The engine was previously turbocharged making over 300hp this one could be putting down 450. I will have to get a dyno sometime in the future to dial it all in. The Hp numbers really arent that important to me as I thought the car was plenty fast the way it was before what ever it was putting out, its just when your in there redoing everything, things tend to get out of control and something like this gets built.
The car is off to the body shop next week for the paint.
87 924S
Lexus SC400
Lexus LS400
Old 08-30-2006, 09:10 PM
So.Cal.914's Avatar
Eyegasms.
Old 08-30-2006, 09:37 PM
