-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   Engine Identification (http://forums.pelicanparts.com/showthread.php?t=314615)
bcheney 11-11-2006 06:57 PM
I have just purchased an engine with the following Identification numbers. I think this is an original 914-6. Can someone verify that all of these numbers add up to it being an orginal 6 engine.
Engine *6404153*
Type 901/38
Case 901.101.101.3R
901.101.102.2R
Cylinder Heads 911.104.306.OR
Oil pump 901.105.141.03
Fan shroud 901.106.101.5R
Cam Housing 901.105.111.1R
901.105.111.0R
Conrad W Peden 11-12-2006 08:24 PM
These links might help:
http://www.914club.com/specs/engnumbs.php?PHPSESSID=6bcb64174fccb4f2131e55471b3 29d55
http://www.928porsche.net/history914w.htm
bcheney 11-13-2006 09:27 AM
Thanks for the links. The Second is great!
freezing14 11-15-2006 01:17 PM
engine number
you have in deed the real thing ,, all 914-6 had the 640xxxx number and it should be punched on the flywheels side not the fan,, the case number is also correct as the 0 r and 1R are 911 case#
