bcheney's Avatar
Engine Identification
I have just purchased an engine with the following Identification numbers. I think this is an original 914-6. Can someone verify that all of these numbers add up to it being an orginal 6 engine.
Engine *6404153*
Type 901/38
Case 901.101.101.3R
901.101.102.2R
Cylinder Heads 911.104.306.OR
Oil pump 901.105.141.03
Fan shroud 901.106.101.5R
Cam Housing 901.105.111.1R
901.105.111.0R
08 Cayenne V6
89 911 Targa Carrera 3.2
75 914-6 Conversion
Old 11-11-2006, 06:57 PM
Conrad W Peden's Avatar
These links might help:
http://www.914club.com/specs/engnumbs.php?PHPSESSID=6bcb64174fccb4f2131e55471b3 29d55
http://www.928porsche.net/history914w.htm
We'll be having an ISO9000 audit soon.
I've divided our preparation tasks into two groups: Unethical and Unproductive.
Old 11-12-2006, 08:24 PM
bcheney's Avatar
Thanks for the links. The Second is great!
08 Cayenne V6
75 914-6 Conversion
Old 11-13-2006, 09:27 AM
engine number
you have in deed the real thing ,, all 914-6 had the 640xxxx number and it should be punched on the flywheels side not the fan,, the case number is also correct as the 0 r and 1R are 911 case#
9140431696 painted, with wheels and brake , with all elctrical working , engine in assembly soon to be driven
011850275 911S soft window targa next in the garage
2000 S4 stage 2
660R stroked
Old 11-15-2006, 01:17 PM
