Necromancer's Avatar
Full Throttle when starting...
I know you’re all busy…
I’ll give you the basics…
‘76 914 2.0, Stock D-jet…160K miles. I have had the car for 2 years.
Never had issues except hot starting about a year ago…replaced the CHT (temp 2). That fixed it for the most part…still does it from time to time.
The other day, I washed, drove x2, and put to bed. Next day, turns over but no start. Fuel pump runs, injectors click, smell fuel (badly), no leaks…nothing. Bypassed the CHT by grounding to the battery and it starts...whew...problem solved. However, during this week I think I may have dumped like a gallon of gas in the intake from starting it and testing things over and over...I know, I know...rookie. Anyway, the car starts great, but it's at full throttle..like red line. I've checked the linkage and all is ok. Why is it starting at full throttle? I mean, I can't keep it on b/c it's redlining. I can't seem to find where the throttle would be stuck...I never touched the linkage or throttle body. One thought I had was that once the gas in the intake was burned, it would be ok but I'm not sure.
Any ideas?
Thanks all…love the site.
Take care,
Nec
Old 03-31-2007, 09:11 PM
Take the air cleaner off and look at the butterfly in the throttle body. Is it closing squarely?
Old 04-01-2007, 11:07 AM
No...it's not. Is is supposed to and how do I adjust it? How could it just get like that?
Thanks for the response.
Nec
Old 04-01-2007, 11:48 AM
Conrad W Peden's Avatar
Sounds like it could also be a vacumm leak. Check all your hoses.
We'll be having an ISO9000 audit soon.
I've divided our preparation tasks into two groups: Unethical and Unproductive.
Old 04-01-2007, 02:14 PM
Whew...clutch linkage was interferring with the throttle cable at the pedal cluster. Easy fix...thanks all.
Old 04-01-2007, 05:24 PM
