Throttle cable bracket for dual Webers
Just got dual Webers (44 IDF's) for my '73 2.0. What can I use to bracket my throttle cable, and where is the best place to locate the bracket?
Your creativity will be your only limit.
I got ahold of some 1/8" steel plate cut and bent and drilled till I came up with something that did not flex forward or aft. it sits inbetween the oil fill stand and uses the 10mm stud as a mount point and also a 13mm bolt on the case. Tough to get pictures. Been through several designs that all got bent after a few too many WOT excursions. |
