Post Is the Welt. short shift kit for 914 the same as for 911?
I found one for the 911 and need to know if it works in the 914.
Old 08-15-2001, 09:08 AM
Germain's Avatar
Post
Not from my 73 914 vs an 82 911 SC. They are differant.
Old 08-15-2001, 12:30 PM
DDS DDS is offline
Post
I'm pretty sure its the same as for an earlier 911 with the 901 transmission.
Old 08-15-2001, 12:37 PM
JmuRiz's Avatar
The 911 kits works for the pre 1972 914, but the 1973 and later 914 kits are different. I have also heard that the short shift kit for the 914 is not a good idea unless your shifting is good and positive to begin with. If you have a sloppy shifter now it will be amplified w/ shorter throws. If I were to install a short shifter I would also replace all the shift bushings! Good luck.
Nathan
'73 2.0 914
[This message has been edited by JmuRiz (edited 08-15-2001).]
Old 08-15-2001, 12:41 PM
Post
Here is my problems.
901 shifter, box, linkage, etc. into a beetle. Having shifting problems, too much travel in the shifter w/ the longer linkage I built. I want to try the 911 901 short shift kit to see if it helps. If it doesn't I want to move it to my 76 914. It sounds impossible since the 914 73+ you stated uses a different short shift kit?
Old 08-16-2001, 08:38 AM
