Arizona_928's Avatar
a 6 engine mounts for a 914-4??
is there any really good ones around? ones to avoid? anything cheaper then the $500 one i saw on evilBay??
dolor et pavor
Copyright
Old 04-12-2008, 07:08 PM
rfuerst911sc's Avatar
I am not a expert but I am doing a /6 conversion so I'll give you my thoughts for what their worth. First off I am installing a stock 3.0 with carbs so when I was doing my research this engine fell into the higher hp category. From the research I did most guys said to stay away from the " quick 6 bar " type of mount which is the type that uses the stock four engine mounting points on the chassis. I ended up useing the Rich Johnson mount which installs on the firewall. Yes it's pricey but it is a quality piece and I'm pretty sure my engine will stay where it's supposed to with this mount. If you are using a lower hp engine like a stock 2.0 maybe you can use the stick type mount. At the very least if I were to use one I think I would do some strengthening to it as they seem to be a little " flexible ". Good luck with your choice.
Old 04-13-2008, 06:29 AM
Scrappy's Avatar
Spend the money for the Rich Johnson mount .... as close to factory you're gonna get. The only problem with it is you have to install the front sheet metal after installing the engine. Tin won't clear the mount when installing. (my experience ... yours may differ).
Ron Meier
Backyard Shadetree Mechanic
1974 914/6 conversion with 2.7L (The Grey Ghost)
1973 Chalon with 2.4T MFI (Schlitzalom)
All my 4 cylinders are gone
Old 04-13-2008, 07:39 AM
914 Geek
Pelican also carries the Rich Johnson mount. Good stuff; I would not consider the "quick six" type of mount that replaces the motor mount bar.
--DD
Old 04-13-2008, 02:55 PM
SirAndy's Avatar
--DD
i agree with DD!
RJ mount is the way to go ...
Andy
welded in:
painted:
moneyshot:
>> 1970, 914-6, 3.6L (Conversion)
>> 1970, 914-6, #374 (Original)
>> 1975/73, 914 Limo (Custom)
Old 04-16-2008, 03:32 PM
sww914's Avatar
I've been maintaining a 914-6 racecar with a 2.2S for a couple of years and it has a quick 6 mount. We haven't experienced any problems with it but it is in the way a little bit sometimes. Just to play the devil's advocate, what's so wrong with them? I've seen plenty of A/M parts that I hate but this isn't one of them.
Old 04-17-2008, 06:56 AM
914 Geek
There are some lovely-looking tubular steel ones. They act as a big spring, and the engine bounces up and down. The mount will then fatigue and fail, leaving your motor dragging...
There are ones that look like they are made out of 75 lbs of square tubing and plate. They are heavy and ugly, and need to be chopped up to fit the side-shift linkage.
Not sure about the others.
The RJ mount is similar to the way the factory mounted the engine, but stronger. Best there is IMHO.
--DD
Old 04-17-2008, 07:27 AM
PCA7GGR's Avatar
A few years back, I shared a 2.4S 6 racecar with a quick6 style mount (not sure of origin). Mount broke at a Crows Landing event (alright, how many old timers remember that TT/DE site?), we welded it Saturday night and it broke again Sunday (during my partner's timed run - no timed runs for me). Replaced the cross bar mount with a factory one and had no problems after the change out.
+1 on Rich's mount - factory ones are getting hard to find and a bit pricy.
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 04-17-2008, 07:46 AM
Control Group
Tobra's Avatar
I presume you read this
http://www.pelicanparts.com/914/914-6_construction_kit/914-6_info_guide.htm
James Montebello passed away, so the link to him is probably no good anymore
Old 04-17-2008, 12:47 PM
SirAndy's Avatar
trekkors "quick six" mount broke during autocross. the welds came apart ...
Old 04-17-2008, 02:23 PM
sww914's Avatar
Well, I guess I know what's wrong with them now, they break!
Old 04-17-2008, 02:50 PM
JW Apostate
trekkor's Avatar
My Patrick chromemoly tubular mount did break, yes.
I had it tig welded and it is fine now.
The welder said, "if that breaks, I don't want to be there".
At this point, I feel it's the strongest part on my entire car!
The original welds were awful.
As far as the motor falling out or dragging...Nope, can't happen.
here's some pictures:
The penetration of the welds were awful and service from the maufacturer was not satisfying at all.
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 04-19-2008, 08:09 PM
JW Apostate
trekkor's Avatar
Here's the repair shots.
Quality welding.
It's survived about 40 track days now and about 20 a/x's.
I had it welded about two years ago or so:
Can I recommend the part? I don't know
Now that mine is repaired, I love it.
Super easy to install the motor.
KT
'01 Boxster
Old 04-19-2008, 08:15 PM
JW Apostate
trekkor's Avatar
As for the motor 'falling out'. Here's why that can't happen.
Mine broke as bad as it can. The mount plate that attaches to the engine itself seperated fron the cradle on the bar. The motor drops about 1" and pivots foward slightly. The mount plate bolts catch on the cradle and that's it.
The car was still drivable.
KT
'01 Boxster
Old 04-19-2008, 08:24 PM
John Rogers's Avatar
As Dave said any mount that mounts the engine and then goes clear out to the original stock pads will flex and the engine will bouce. While a good idea it proved to be problematic as the engine is heavier and the tube was not as stiff as the forged original 4 mount. Patrick now makes a bulkhead mount that uses a mount similar to the stock piece that mounts to the engine and a short tude section with dual feet that attach to the bulkhead where there are two raised metal sections. This uses bushings to capture some vibration and a big advantage is the engine and trans can be lowered at the rear which makes trans swaps super easy. Quite a few vintage 2L class race cars (912s and 914s) that have been converted to sixes use them.
Old 04-19-2008, 08:28 PM
JW Apostate
trekkor's Avatar
If it flexes, then the stock motor mounts are too.
I'd love to see how much weight it actually takes to bend one of these pieces.
Mine was bad welds... the pictures are clear.
KT
'01 Boxster
Old 04-19-2008, 09:00 PM
914 Geek
The original 914-4 mount is much more solid than many or most of the aftermarket bar mounts, and is supporting something like a couple of hundred pounds less weight.
There are other cases of the bar mounts failing; I know of no cases of the Rich Johnson mount failing.
--DD
Old 04-20-2008, 06:59 PM
lol.. and i was hooked after the 3rd reply
dolor et pavor
Copyright
Old 04-21-2008, 07:23 PM
