Post valve adjust lock nut stuck
so i try to do a valve adjust on a motor and the 13mm hex locknut holding the screw is stuck. pb blast and try again ... anyone have an idea or info on replacement?
Old 10-19-2001, 05:41 AM
Post
if you can't get it loose, you could always remove the rocker arm assembly. i think the assembly is held on by 2 10mm nuts. maybe you could loosen it on the bench.
Old 10-19-2001, 06:15 AM
