so i try to do a valve adjust on a motor and the 13mm hex locknut holding the screw is stuck. pb blast and try again ... anyone have an idea or info on replacement?
if you can't get it loose, you could always remove the rocker arm assembly. i think the assembly is held on by 2 10mm nuts. maybe you could loosen it on the bench.
