airkooled05's Avatar
Talking Carb Issue on 914
My neighbor just purchased a 914 with carbs . He has been driving it a week and all of a sudden it started running poorly . A low rpm miss . I know nothing about carbs but he pulled the little ( jets ? ) four of them on the side of the carbs to clean them . He noticed when he pulled them one was missing an 0 ring . Would this be enough to make it run poorly as described . Any input would be appreciated
Old 07-19-2009, 07:36 PM
there are two of these for each carb . webers
Old 07-19-2009, 07:37 PM
The o-ring maybe stuck in the body of the carb which happens sometimes. Not a problem really, the jet will just unscrew from the body and the o-ring stays with the carb. If you didn't have an o-ring at all, you'd have gas dripping out.
Old 07-20-2009, 05:12 AM
Thank you
I dont see it but I will look again this morning . We still have to figure out why it is missing all of a udden . Thank you kindly for your input
Old 07-20-2009, 05:29 AM
Idle jets can still be plugged. or a piece of junk stuck in the idle circuit. pull the jet spray some carb cleaner in it and watch whereit comes out of in the progression ports and the idle needle valve.
Old 07-20-2009, 05:57 AM
Thanks , thats how it acts . We ad a tornado hit here Monday night . Neighbor lost his car to a tree . I guess my problems are small . Any way thanks for the input .
Old 07-23-2009, 05:16 PM
Idle Jets are cleaned
It now idles perefectly however it is running a bit rough . It is back firing on deceleration and it back fires just a second or so after the ignition is shut off . Not sure if that is mechanical or electrical . Thanks
Old 07-25-2009, 10:03 AM
