Rear Hub Removal
How do you remove the rear hub on a 914 from the control arm? I have the axle removed but can't make any progress removing the wheel hub.
LW
Old 03-03-2002, 07:02 PM
Zeke's Avatar
Go to: http://www.pelicanparts.com/techarticles/914_five_lug_conversion/914_five_lug_conversion2.htm
To avoid damaging anything from an errant blow from the hammer, I used blocks of hardwood.
Good luck,
Old 03-03-2002, 07:37 PM
Zeke914,
Thanks very much for the information that you provided for removing the rear hub. The information in the article was perfect to the "T". Everything worked just indicate in the article.
LW
Old 03-06-2002, 12:22 PM
