gtc gtc is offline
abides.
gtc's Avatar
Are they all 1-4-3-2 ?
I was helping a friend replace his plugs, wires, cap and rotor a few days ago. I put the wires on the cap in 1-4-3-2 order, which I thought was the firing order for all 914-4's. We test fired it in the garage and it seemed to run fine, but after I had left and he went to fire it up, he said it wouldn't run right. Eventually, he says, he switched the wires to 1-3-4-2 and it ran normally again. Does this make sense? I am trying to figure out what I'm missing here....
Thanks,
Graham
1984 Carrera Targa
Old 07-13-2010, 02:04 PM
SirAndy's Avatar
1-4-3-2 is correct.
Make sure the dizzy drive shaft wasn't put in 180 degrees off. DAPO tend to do things like that. Took me weeks to figure that one out ...
Andy
>> 1970, 914-6, 3.6L (Conversion)
>> 1970, 914-6, #374 (Original)
>> 1975/73, 914 Limo (Custom)
Old 07-13-2010, 02:52 PM
gtc gtc is offline
abides.
gtc's Avatar
Thanks.
That had occurred to me, though I can't imagine how an engine would even run when 180 deg. off of an incorrect firing order.
I guess more investigation is called for.
Graham
1984 Carrera Targa
Old 07-14-2010, 01:41 PM
