-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   no spark (http://forums.pelicanparts.com/showthread.php?t=56027)
akgrown 01-06-2002 04:44 PM
no spark
have purchased new volt reg., 009 dist with electonic egintion, and pertronix coil and the engine(73 1.7) was started. one day later have no spark but the coil is getting power, and checks out with the test given in Bently manual, but is not producing a spark out of plug or off of secondary(to dist.). thanx
kellzey 01-06-2002 04:59 PM
You say you have an electronic ignition. Is it a Pertronix Ignitor?
I installed the Ignitor in my 1.8L car that I recently sold. It worked excellently.
I recently sold the car and the new owner called me the next day. Said that the car would turn over, but no spark. Coil was fine, etc.
Upon closer examination he found that one of the wires leading to the ignitor black box under the distributor cap had come worked it's way out of the housing. He jammed it in there and epoxied it shut and it's been working fine.
Just an idea...
Also, I once had a set of faulty Bosch spark plug wires. Turned out one of the wires had broken free of the metal connector that clips into the spark plug. It looked intact, but upon closer inspection there was no spark. Replaced that one wire and it worked like a champ.
I would check two things... connection between your coil and distributor and your black box connections.
Good luck!
Karl Ellzey
(914-less) I wish I had one again. Previous owner of three different 914s.
I have a new Boxster, but it's not the same.:(
kellzey 01-21-2002 05:08 PM
re: No Spark
Did you ever resolve your problem?
Just curious.
Karl Ellzey
2001 Boxster
Currently 914-less :(
akgrown 01-26-2002 10:18 PM
yes and thanks kellzy,
the electronic ignition(brand new) was shot. the back of the little black box inside the distributor was melted away....? went back to ol' school techniques and it worked. imagine that.
