ok how to not feel guilty sawzalling a 914?
I have #840, completely rusted out, both longs you can look through to the hell hole, and the front of the pan where the pedals are is completely gone.
Can't summon the courage to pull out the sawzall to her. ![]()
dolor et pavor Copyright |
SAIGON 68
pretend it's a vw
Resident Electrician
Please add the VIN to the data base at 914world.com
If the car is not a special one (-6 or LE) let the saws all rip! I have one like that I'm cutting up. I did sell the 5 lug set up first.
Current Project: 73 914, 1.8t, ~300hp, 930 Brakes, Roll Cage Past Projects: 69 911, converted to C2 wide body cabriolet 3.2L 72 914, Ford 5.0L V8 EFI |
This poor car has had a rough life. The engine was seized when I bought it, nothing salvageable but the case and trans. It has been parted out to where it's just a tub with suspension, wiring, and powerplant. I could use the body parts for my 71...
Ha it's a VW!!!!
914 Geek
Invite some other 914 folks over. Make a party of it.
If there are good parts, save them. Better yet if you can get people to ask for the parts ahead of time, so you know exactly what not to cut up. That way you can rationalize that the rotted car is sacrificing itself so that other 914s may live... --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Pull the wiring harness. Some of that wiring will come in handy if you need to repair something in another car and want to use the same color scheme. (makes troubleshooting much easier years from now.
Cut it up. Could use the knee pad of that early car if you still got it. |
I agree ...
>> 1970, 914-6, 3.6L (Conversion) >> 1970, 914-6, #374 (Original) >> 1975/73, 914 Limo (Custom) |
it'll go to a "better place".
canna change law physics
I Sawzalled 2. They were both better off.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
sawzall
had a parts car that buckled when attempting a lift----no remorse it was shot.....got a lot of parts.
'72 1.7 under renovation |
