Back in the early 80's I had an experienced mechanic build me a 2.4 liter type four motor with European racings 103x71mm kit. The first build sucked a valve before the 15k mile mark and the second time one of the rings gave out before it made it to 15k miles. Each time I spent around $5k to build it or fix it.. After that I installed a stock 2.7 six with Webers and it ran over 100k miles before it started pulling head studs. The 2.7 only had a top end overhaul when I bought it for $3500.00. Instead of overhauling it I bought a 3.2. This motor has well over $150k miles with zero issues and still has good compression. After getting burned twice I am a little biased against big type 4's.
Steve 75 914-6GT clone with a 1995 3.6 DME motor, 915 trans with Martin Bott 916 shift kit, MB911 heat exchangers, boxster brakes, etc... Special thanks to Patrick Motorsports for fixing my 915/916 trans and there associated 3.6 conversion parts. |
If you call Chris, have him build you a motor...he does a great job and stands behind his work.
Ed who works for him is a genius with motors...you are in good hands. Drop down to Hartford for a visit, listen to his advice, give him a try, you will be happy. rich |
914 Geek
Sorry, Randal--that was not directed at you or anyone specifically. Just a mention that quite a number of people who haven't built or lived with Big Fours will be happy to offer opinions on them. And I am one of that number, I have lots of opinions but little direct experience.
My intent was that people who have been-there-done-that are more worth listening to than Those who have not. (Which doesn't stop me from talking. )--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Building any motor is a nose bleed.
Building big 4's can be worse as the process/ technology isn't exactly documented. The good news is that there are steller people out there that can help and are willing to do so. References upon request.
Randal |
