Front pads on rear calipers?
I've been reading some articles and some say you can use the front pads on the rear calipers of 914s. Is this possible?
I do know you can use the front calipers on the rear, but I do not want to do this at this time.
Thanks for your input.
Duane
'03 M3 Coupe, '65 Mustang 2+2, '72 Cherokee 140
Old 06-25-2002, 06:15 AM
rockaria's Avatar
On my 75 1.8 with original calipers they are very different. I did an upgrade to 5 bolt lugs using 914 rotors and hubs that I had drilled, and then I used the original brakes. I ordered a kit to do the whole process with full bearings, seals, studs, lugs and it came with 4 very similar (Same size) brake pads. I went to put in the rears and they were too large. A quick call and I was able to get the correct smaller pads I needed.
This is only my expirience on a stock 1975 1.8.
I hope it helps,
Christopher A. Landt
1979 911sc
1973 914 2.0
Old 06-25-2002, 07:34 AM
Perhaps... you are referring to moving the front calipers to the rear of the car.... Alot of people do this when they upgrade their front brakes to a larger non stock caliper.... You essentially loose the parking brake. I don't think the actual front pads will fit into the stock rear calipers.
brant
Old 06-25-2002, 09:33 AM
