Battery Question
I am interested in using a Optima battery in my 914. Does anyone know the Group # or part # for this brand of battery? Optima's website does not list a porsche application. Thanks..I am also looking for a battery tray
The standard red top Optima you find at your local auto parts store fits using the stock clamp:
http://forums.pelicanparts.com/uploa...1364735768.jpg |
I think it is a Group 42, but I'm not quite certain on that. I believe that you want the one with the terminals swapped left-for-right as well, which would be a 42R. (If they still make those.)
--DD |
Summit told me it is a grp 25 for Optima.Yes a std battery is a 42.also where are the term.posts? side or top The part# they gave me was ult9022091. Just want to get the correct one.also 720CC amps. Thanks for ur help.
The standard battery has the posts on the top. The Optimas I have bought in the past had both top and side posts.
I think I may have had to mount my Optima battery turned around backwards to put the posts in something closer to the right locations, but I may be misremembering that. I just put the ground post closer to the front of the car and the hot post closer to the back of the car, whichever way that puts the battery. --DD |
Battery Model: 35
Part Number: 8020-164 (Posts only on top in the correct location for the 914) |
I am running a battery for a gold wing in my 930 and it seems to work fine. I am going to look for the same for my soon to be in my driveway 914. It has a rating of 400cca, but actually tests in around 450cca which is more than adequate for a 4 banger. It also cranked my mustang with a 347 10.25:1 motor. I was quite impressed and was only $130 at Batteries Plus. It is an agm battery too.
35R or 78 optima will fit the 914
| All times are GMT -8. The time now is 11:46 AM. |
