I am interested in using a Optima battery in my 914. Does anyone know the Group # or part # for this brand of battery? Optima's website does not list a porsche application. Thanks..I am also looking for a battery tray
The standard red top Optima you find at your local auto parts store fits using the stock clamp:
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
914 Geek
I think it is a Group 42, but I'm not quite certain on that. I believe that you want the one with the terminals swapped left-for-right as well, which would be a 42R. (If they still make those.)
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Summit told me it is a grp 25 for Optima.Yes a std battery is a 42.also where are the term.posts? side or top The part# they gave me was ult9022091. Just want to get the correct one.also 720CC amps. Thanks for ur help.
914 Geek
The standard battery has the posts on the top. The Optimas I have bought in the past had both top and side posts.
I think I may have had to mount my Optima battery turned around backwards to put the posts in something closer to the right locations, but I may be misremembering that. I just put the ground post closer to the front of the car and the hot post closer to the back of the car, whichever way that puts the battery. --DD
Battery Model: 35
Part Number: 8020-164 (Posts only on top in the correct location for the 914)
Work to Live, don't live to work... |
I am running a battery for a gold wing in my 930 and it seems to work fine. I am going to look for the same for my soon to be in my driveway 914. It has a rating of 400cca, but actually tests in around 450cca which is more than adequate for a 4 banger. It also cranked my mustang with a 347 10.25:1 motor. I was quite impressed and was only $130 at Batteries Plus. It is an agm battery too.
John- 78 Slick Top 930 "Illegitimi non carborundum" |
35R or 78 optima will fit the 914
Scott 88 911 G50 3.2 Targa Signal Red DP935 NA 95 993 C2 Coupe Black/Black 99 996 C2 Silver/Blue 77 911S GP White/Cork |
