914 rod bolts
I am presently rebuilding a 1.7 that was big bored to 96mm pistons and cylinders. I want to take the connecting rods off the crankshaft to inspect the bearings and replace if nescessary. My question is do I need to replace the bolts(studs) and nuts or just the nuts? Also is there a place on the web where I can locate torque and measurement specs for a 914 4 cylinder engine? Thanks for any input.
Mike.
Old 04-24-2013, 06:19 PM
914 Geek
The factory printed a Spec Book (often called the "little spec book" because it is quite small) for each model with torques and tolerances and measurements. The 914 spec book has been in and out of print a couple of times as I recall; I am not sure it is currently available.
The Haynes manual has most or all of the torque specs from the Factory manuals. I don't think it has as much info on tolerances and measurements, but it does at least have some.
You can try looking in the Classifieds section of this BBS, and the similar one on the 914world website, to see if anyone is selling a copy of the spec book.
--DD
Old 04-24-2013, 11:03 PM
