-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   2L going back. Which sealant?? (http://forums.pelicanparts.com/showthread.php?t=748876)
kachemakian 05-08-2013 08:00 AM
So I am ready to put the case halves back together with all brand new/30 year old stock OEM bearings, seals and gaskets. I was told by an "old time" Porsche mechanic that the best product to seal the case halves with was Permatex 300. I have not been able to locate any 300. What is the best "current" sealant commonly available?
Leon in Alaska
Joe Ricard 05-08-2013 08:11 AM
Loctite 518
Nostril Cheese 05-08-2013 11:43 PM
Hondabond will work as well
porschetub 05-10-2013 10:37 PM
Originally Posted by Joe Ricard (Post 7430037)
Loctite 518
Numbers vary on the Loctite sealants worldwide,but IMHO any of the non-setting "mastergasket types" will be great.
Don't use the flange sealant/gasket eliminator setting type as it will leak due to case movement due to heat.
Haven't had a great run with Permatex so won't recommend,go for the 518 ;););)
yeahmag 05-13-2013 03:47 PM
Curil-T and Curil K2 are the current generation of sealants I'm using.
