2L going back. Which sealant??
So I am ready to put the case halves back together with all brand new/30 year old stock OEM bearings, seals and gaskets. I was told by an "old time" Porsche mechanic that the best product to seal the case halves with was Permatex 300. I have not been able to locate any 300. What is the best "current" sealant commonly available?
Leon in Alaska
Old 05-08-2013, 08:00 AM
Loctite 518
Old 05-08-2013, 08:11 AM
Hell Belcho
Nostril Cheese's Avatar
Hondabond will work as well
Old 05-08-2013, 11:43 PM
porschetub's Avatar
Originally Posted by Joe Ricard View Post
Loctite 518
Numbers vary on the Loctite sealants worldwide,but IMHO any of the non-setting "mastergasket types" will be great.
Don't use the flange sealant/gasket eliminator setting type as it will leak due to case movement due to heat.
Haven't had a great run with Permatex so won't recommend,go for the 518
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 05-10-2013, 10:37 PM
Curil-T and Curil K2 are the current generation of sealants I'm using.
Aaron McKinnon
'74 2.0L 914
'66 Drag Bug -SOLD-
Old 05-13-2013, 03:47 PM
