-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   No left blinker under braking (http://forums.pelicanparts.com/showthread.php?t=749972)
pgeorgeson 05-14-2013 03:24 PM
Left blinker works fine as long as I am not braking. When I brake, blinkers stop blinking (and go out). Advice (other than quit braking)?
Dave at Pelican Parts 05-14-2013 04:33 PM
Well, they do just slow you down... ;)
I would start checking the wire connections on the front and rear turn signal buckets, and the front side markers. Make sure you don't have anything switched around; if you do all sorts of odd things can happen. Also double-check that you don't have any single-filament bulbs where dual-filament ones should be, or vice-versa. (Look for two prongs down in the bottom of the bulb holder to tell if a holder expects a dual-filament bulb.)
Then clean up the grounds for the front and rear buckets--that's always a good idea anyway....
--DD
