pgeorgeson's Avatar
No left blinker under braking
Left blinker works fine as long as I am not braking. When I brake, blinkers stop blinking (and go out). Advice (other than quit braking)?
1964 356 C
1970 911T
1974 914 2.0
1986 Carrera Spec911 race car #76
1990 Carrera 2
Old 05-14-2013, 03:24 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Well, they do just slow you down...
I would start checking the wire connections on the front and rear turn signal buckets, and the front side markers. Make sure you don't have anything switched around; if you do all sorts of odd things can happen. Also double-check that you don't have any single-filament bulbs where dual-filament ones should be, or vice-versa. (Look for two prongs down in the bottom of the bulb holder to tell if a holder expects a dual-filament bulb.)
Then clean up the grounds for the front and rear buckets--that's always a good idea anyway....
--DD
Old 05-14-2013, 04:33 PM
