Benet's Avatar
Question Distrib. Vac. Advance messing up???
The car will start and it'll idle rough, but when you slightly push down on the vacuum advance on the distributor it idles perfect, you let go and it almost dies trying to idle. Buy a new vacuum unit or is this a easy fix?
1974 1.8L still FI
Thanks guys! Jay
'90 911 C4 Targa
'74 914 2.0L FI (past away)
Old 07-29-2002, 07:07 PM
well to me it sounds like the advance plate in the dizzy is loose and letting the points go nuts
check the ball bearing in the dizzy to see if it is there if not i can check to see what size it is and you can pick one up
or remove the vac advance and lock the plate some how, it does not do much anyway, just off idle after that nothing
have you timed the car right ie: removed and cap the vac line and timed it to 7.5 degrees
i just looked at my spare dizzy it looks like when i push down on the vac chamber it would pull a little retard in, if it where loose, i would try to time it again
scott thacher
75 914 with 2.5 l 98 suby engine on the road
Old 07-29-2002, 07:32 PM
