Stay away from my Member
campbellcj's Avatar
Porsche Crest Strut/caliper/rotor question
My dumba$$ question of the day:
Is it possible to remove or swap the spacer from 911 "A" calipers and use them with a solid 914/4 rotor, drilled to 5-lug?
OR, is there a 3.5" bolt spacing ATE caliper that will work with a 914/4 rotor?
WHY would anyone want to do that, you ask? Give you one guess...
Yep, I am maxed out on class points (POC V5; plenty left in PCA AI), and I can upgrade calipers but no rotor mods. So I could either do the 320 calipers on my 3" struts or use the 3.5" struts (and potentially mondo calipers) somehow with 914/4 rotors. I can move my 914/4 front calipers to the back.
The other factor is, I found the PO's papers on the suspension parts and the front inserts are P36-0112 HD's -- not -0113 Sports as I had thought/hoped -- and so I may be selling either just the inserts, or possibly both sets of struts I've got (1 914/4, 1 911SC) and going to something else. Whatever I would go to would have 3.5" spacing.
The rears are not a problem; they can be fitted with threaded spring collars, any spring rate I would ever want, and revalved by Bilstein or Smart-Racing as needed. That should do until I can afford (and need) externally adjustable Konis, Ledas or whatever.
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 09-03-2002, 10:40 PM
Brad Roberts's Avatar
Dont make me split a M caliper to check this.
Too late. Your questioned intrigued me. I had never actually tried this. So.. I pulled apart a spare M caliper and tried to bolt it up to a 914 rotor/strut combo.
NO go. Here is why: The 911 caliper has a different offset to be centered on the 911 rotor. The mounting face for the 2 bolts would have to be machined WAY down to get the caliper to center on the solid rotor.
What if we ran the really early 911 5 lug stuff with the solid rotor ? This ran a M type of caliper without spacers, but can be converted to a vented rotor and vented M caliper later.
This is the M without the spacers.
Old 09-04-2002, 12:53 AM
campbellcj's Avatar
That's true; an early 911T solid rotor setup might sneak by the classification nazis. But not sure there is much advantage vs just doing the 320 calipers on a drilled 914/4 setup; plus the bimmer calipers would be brand new vs 30 year old rebuilts.
Hell, for now I have no problem trying the stock brakes. The car is not THAT much faster than a stock 2.0; I would probably be fine.
Chris C.
Old 09-04-2002, 12:57 AM
Just get proper cooling to them. That is all they need anyway.
Ask them about the solid rotor 5 lug setup.
The parts places almost give these strut assemblies away.
B
Old 09-04-2002, 01:06 AM
What kind of pads are you using? If they are not carbon fiber, go get a set. You would be surprised at how much difference they will make on stock brakes. Get some more front calipers to use one the rear; use a brake balancer and I bet you will be more than happy for a long time.
Old 09-05-2002, 05:32 AM
campbellcj's Avatar
Mark - yeah, unlike a lot of guys, I have faith in the stock brakes (when set up right). I am really just planning ahead for when the car (hopefully) gets its steroid infusion to 250-300hp and a lot more tire.
I hate redoing stuff, so I was hoping to come up with a trick setup that would fit my current class and not be too out-gunned later.
With the same brake setup I had on the last car, plus some cooling to the fronts, I'll be fine for now. Not like I need to spend a bunch more money anyway.
Chris C.
Old 09-05-2002, 10:19 AM
you might want to read this. It puts it in perspective.
http://tech.rennlist.com/911/pdf/Brake_Power_vs_Weight.PDF
Old 09-05-2002, 10:33 AM
Mark,
You say carbon fiber..
Give me a company name that I recognize.
We run Porterfields for the most part currently.
B
Old 09-05-2002, 02:21 PM
That's one, Performace Friction, Hawk
Old 09-05-2002, 02:43 PM
campbellcj's Avatar
Carbon-Kevlar is what you mean, right? (Same difference, carbon based composites).
I think most of the race pads are organic (carbon-based), non-metallic, non-asbestos compounds these days.
Chris C.
Old 09-05-2002, 03:53 PM
