Va914's Avatar
911 struts and hubs?
Hey guys..About a month or so ago I bought a '74 911 front end for $250.
This included very ggod condition struts, very good condition calipers, caliper harware, and adj Koni shocks. I thought all I needed was new rotors. Well to my suprise, it now seems the 911 front end uses hubs??? What is the going price for hubs and did I get hosed?
Kerry (Back on the road, sort of)
914-6 in the Werks
Old 09-04-2002, 10:22 AM
JWest's Avatar
Well, you do need the aluminum hubs, grease caps, and bolts to attach the rotor. Hopefully you can find a set for a decent price - FYI 944s use the same.
Old 09-04-2002, 10:57 AM
Stay away from my Member
campbellcj's Avatar
That is a good deal, esp if they are "A" or "S" struts (3.5" spacing) but usually the 911 setups are sold with the hubs/rotors/studs and everything all bolted together.
Do you have bare struts & standalone calipers, or the whole front-end?
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 09-04-2002, 10:59 AM
Va914's Avatar
I have the stand alone struts, calipers, shocks. I think they are M style.
So the 944 shares the same hubs and hardware? Hummm. Any years I should stay with?
Kerry
914-6 in the Werks
Old 09-04-2002, 11:05 AM
JWest's Avatar
Yeah, just wheel bearings out. Only the hub and rotor matches between 911 and 944, but that's all you need and the 944 people might not be as proud ($$) of their parts. '83 to '86
Any 911 ('65 to '89) hubs will work also.
Old 09-04-2002, 11:18 AM
Va914's Avatar
Thanks. I'll keep any eye out on the 944 board and 911 board for hubs and hardware.
It never endsssssssssssssss
Kerry
914-6 in the Werks
Old 09-04-2002, 11:22 AM
philinjax's Avatar
Kerry,
Make sure your strut spindles have the little spacer rings mounted (the first thing that goes on the spindles). These
rings are press fitted. Ask me how I know.
Phil
Old 09-04-2002, 12:59 PM
Va914's Avatar
I found a set of 87's from a 944? Does anyone know if they will fit struts of a 911 '74 vintage?
914-6 in the Werks
Old 09-04-2002, 06:26 PM
JWest's Avatar
In '87 the wheel offset on the 944s changed - the classic fuchs (as used on 911s and '83 to '86 944s) won't fit on an '87 or later 944. I would think the hubs would be different. My educated guess would say keep looking.
Old 09-05-2002, 05:34 AM
Va914's Avatar
Thanks.. I'll have to pass on the '87 hubs. They were a good deal too
How about 914/6 hubs? I assume they will fit the '74 911 struts.
914-6 in the Werks
Old 09-05-2002, 05:45 AM
JWest's Avatar
914/6 hubs will work.
Old 09-05-2002, 06:52 AM
Va914's Avatar
Thanks for the help guys I think I found a pair. Now I just need to see if I have the "little spacer rings" on the struts. But I'll save that for another day.
Again thanks,
Kerry
914-6 in the Werks
Old 09-05-2002, 07:15 AM
