Turn Signal Issue
When the cockpit temperature is above about 80 degrees and I signal for a left turn the dash indicator flashes once then goes off. The outside front and rear turn signals do continue to flash. This does not happen with a signal for a right turn. Is there a contact somewhere that I can add a drop of solder to?
Old 08-17-2014, 10:53 AM
914 Geek
When I had a similar problem, replacing the turn signal relay fixed it. You might be able to open yours up and clean/refurbish it.
--DD
Old 08-17-2014, 03:48 PM
Turn Signal Issue
Dave,
Thanks. Where is the subject relay located?
Old 08-20-2014, 02:38 PM
914 Geek
On top of the fuse panel. It is one of the boxes up there.
--DD
Old 08-20-2014, 03:05 PM
Control Group
Tobra's Avatar
you may be able to use a relay from a VW of some sort and save some dough. Headlight relay was much less expensive from local A/C VW place
Old 08-20-2014, 06:41 PM
