Has anyone used a 215mm Bus Clutch?
Has anyone successfully used the 215 MM VW bus Clutch disk in their 914?
Duane
'03 M3 Coupe, '65 Mustang 2+2, '72 Cherokee 140
Old 10-07-2002, 07:33 AM
norustscott's Avatar
I have....It is the same part...infact mine was from SACHS and was the "sport" version with the six cushion springs...
Scott
1982 911 SC
1962 sunroof bug
1991 WE Vanagon CARAT WRX conversion
Old 10-07-2002, 08:26 AM
thesey914's Avatar
Do you know if the pressure plate and flywheel are the same too?
Cheers -James
Old 10-07-2002, 08:38 AM
Hey! Nice Rack! "Celette"
rich's Avatar
Did you have your flywheel machined for clearance?
Early Alien Sightings
914-M28/11 5.0 Hybrid (The Alien Sharkster)
I think I smell your blood in the water
WCC 04 done by the kids
Who says Aliens only abduct people.
Old 10-07-2002, 09:41 PM
Griznant's Avatar
Cheers -James
Flywheel and pressure plate are completely different. The 914 flywheel needs to mesh with the Porsche starter properly, and a bus one just won't fit right. The pressure plates I've seen for a bus will not fit the dowel pins on the 914 flywheel. The disc fits, but that seems to be about it.
Later,
G
Old 10-08-2002, 06:42 AM
I agree. The disk in the only VW part to work... you will only save about 20 bucks by going to the VW disc. It is however, IDENTICAL!
Scott
1982 911 SC
1962 sunroof bug
Old 10-09-2002, 08:18 AM
I would say that as long as your disc has not worn out and started to groove the pressure plate, you shouldn't even bother replaceeing it.
Old 10-09-2002, 01:57 PM
