Should my Koni's do this?
I have 2 sets of Koni red adjustables. One set is on the car now. The other is apart. With no springs, etc. on. My question is this:
Should the "shaft" part on the shock be able to be pushed in with some effort AND return to its original position? Mine DO NOT return. Is this normal? Or are they needing a rebuid? Thanks Korijo
If you don't get an answer here try calling 1-800-200-9366 Paragon Products , they should be able to answer any Koni question.
Craig C. Laughlin CAMP 914 |
Springs when compressed or expanded return to the original position. Thats why they are called "springs". They spring back.
Shocks do not return. Shocks absorb the movement and control the rate the springs rebound to the original position. Thats is why they are called "shock absorbers". Class dismissed.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
Pheeeww! Thanks, Paul. Just wanted to be sure.
Korijo
Robert 1975 Porsche 914/4-2.0 1972 Ford F100 Ranger XLT 2006 Ducati Sport 1000 323i.net RangerXLT.com |
I knew someone would throw the gas shock issue back at me. Gas shocks do react differently that oil shocks.
