GA cam profile?
does anyone know what the lift/duration is on the stock cam for a 2.0 GA 4?
thanks evan |
914 Geek
No, I don't. But there is only one stock cam profile for all the VW Type 4 engines. They're all more or less the same.
Well, they weren't necessarily the same originally, but all of the replacement ones you get nowadays are. Uhh, except for the hydraulic lifter cams, which have different ramps on the sides of the lobe. But the point is: a GA replacement cam would be the same as a W replacement cam, and as an EC cam, and so on. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
i ask because i am rebuilding a GA engine in an automotive class and have carbs and was wondering if i could regrind my cam to carburated web-cam specs, i would rather buy the cam but am on a bit of a budget. would i be able to get it close to .423 lift and 270 duration?
I think your best bet would to just go with a new cam.
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/ www.914club.com |
I don't know what kind of class you are in, but cam grinding equipment is pretty specialized stuff.
I would be REAL surprised if the equipment to do it properly is available in a school atmosphere.
Robert 1975 Porsche 914/4-2.0 1972 Ford F100 Ranger XLT 2006 Ducati Sport 1000 323i.net RangerXLT.com |
914 Geek
Sadly, Porsche (and VW) never put those specs out that I know of.
As far as cams go, everything that I have heard in the past few years says "go Web or go home". Put the re-grind in if you want to tear the motor down after that 20-minute break-in run. If you want to be sure it lasts for any real amount of time, put a Web-Cam in. Just ask Tom Perso, who occasionally shows up here and who posts on the Shoptalk Forums. His cam didn't even last through the break-in... --DD
