I'm gathering all new major rubber- door seals, trunk seals, targa top, windshield,windows, etc. Are there instructions "out there" that specifies when and when not to use adhesive? Many thanks.
Dan |
Ideally you don't have to use any adhesives on any of that, AFAIK. Helps with maintenance and reuse. If you get that stuff from 914Rubber Mark it should be well-fitted and not require it. I just did a hood seal that didn't need it and now I'm doing most of the door seals, and I'm not planning to use any adhesive.
Thank you, very much. I didn't know that.
