O.k so I am cursed with my '73 2.0. I finally went to carbs after figuring out I put to big a cam in when I rebuilt. I got a nice set of weber 44's. Took them to my friend thats a wrench first. My clutch was toast also. So after having it for a month he managed to get to my clutch. He was a little unsure doing the carbs so he suggested taking to someone else. No problem I knew of a good wrench that works on 914's often enough. SO I give him a call & he says bring it over. I do & a week & 1/2 later he calls me with the lowdown. I have a small oil leak on the left side of my engine(not real bad). That is on my rebuilt engine with less than 2000 miles. Oh well also I need to get the right distributor(no vacuum advance). I was actually aware of that but I heard you can plug the vacuum advance into the carbs somewhere. No spot on my carbs for that. Well I thank him & head on my way. It was running pretty good. Alot louder though with my new exhaust on there too. I have a little trouble getting it into gear. Rebuilt tranny too(hum), New sachs clutch (hum). Gets worse quickly & won't go into gear without grinding. So I limp her home turning it off at stop lights. Get home to pull her into the garage. Push the clutch in & hear a pop. Clutch pedal stays on the floor. F*&^*#$%&%^&&$%&%&%. Haven't got to crawl under it yet. Did my cable just snap? What do you all think? Sorry this is so long
Jamie Rust 73' 2.0 PacificNW914 club member |
Ouch! Sounds like a snapped clutch cable to me. Also sounds like the tranny might be hosed up too--although I've read that clutch problems can result in problems in the tranny too. Is that the first time you drove with the tranny after the rebuild?
'73 2.0 -- Yellow |
No I've had it for about a year after the rebuild. Haven't got to put much miles on it though. Spent most the time in the garage or in the shop. My last clutch when I pulled it out had tons of life left yet I didn't have any adjustment left. Maybe I got the wrong cable or something. Any suggestions on if Sachs makes a special cable for their clutches?
A broken cable is likely .....and the best thing that coulda gone wrong here. I agree that it may be the problem with your shifting
difficulties. They stretch (all them little wires don't give up at the same time...till right there at the end)before they break causing the clutch to drag....or so I've heard. Lessee, Christmas eve. Where do I get a clutch cable on Christmas eve? I'll bet ole JP has a new OEM cable in his shop.
JPIII Early Boxster |
Cool JP, a regular Santa Claus you are.
Jamie... it's the Dommmiiiinnnooooo effffffectttttttt Don't give up, I think you've begun standing all the dominos up once again! bruce
Sit'n here Hav'n a beer. Punkin's gone (sniff) Gotta mow the Lawn... |
Did you replace the arm bushing and retainer clip? these can be a problem especially if you install a heaver clutch. If it went slowly though it's probally just an linkage adjustment
When I had my boat I used to throw 50 dollar bill at it when ever I went to the dock...now I do it when ever I open the garage door. |
...time to buy a Honda...
Scott 1982 911 SC 1962 sunroof bug 1991 WE Vanagon CARAT WRX conversion |
I agree about the broken cable. One thing to check after you have replaced it. Make sure that with the clutch disengaged (pedal to floor) that the TO bearing lever is not in contact with the trans case. If it is you may not be getting full travel. This could cause your gear crunching. A shim under the pivit ball will cure it. (requires trans out)
Eric '76 914-6 2.7 Auto-x Toy '70 914-6 Orig., in resto |
Old Jp has a clutch cable in his shop heh! Brand new even. WOnder if he's selling it or laughing at me cause I don't
. I'd probably be interested in it JP. Let me know & maybe I'll pick it up at the meet!
I will give you the new, in the package, from the dealer....yada, yada, cable but....there's always a but, eh.... I need a replacement....JIC mine breaks, ya know...and NOT one of them aftermarket PsOS.....an OEM jobbie just like it....say within a month.
Bruce! Bring a couple of critters (or just a few filberts)! I think Jamie has a "new" home for them...
Scott 74 914-6 2.7 |
I already passed drivel here.....number 9
O.k an update! I went to pull the pedal cluster outa my 73 parts car along with the clutch cable. I couldn't get the piece o crap out. Dang nut under the brake lever is killing me. May just cut it out tommorow if I don't get a solution soon. Really pissed me off I got to say! Did get the bumpers pulled for Geoff. Also got the FI pulled for someone else on the BBS. Was going great till I got to that Da*# pedal cluster.
If I remember right, try taking off the rod that goes to the master cylinder to get some room in there. Then the brake petal should move out of the way alittle. Use lots of PB Blaster to beat the rust too on the nut.
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression) www.914Club.com My Gallery Page |
Well I got to admit the lake I was working in didn't help alot. I did take the nuts/bolt outa the master cylinder & got the rod out making the brake lever loose. It is still in the way no matter where it sits. I'm stuck
SAwzall is sounding better al the time
Hmmm, I looked at my parts car and if you push the brake lever towards the front you should have tons of rooms to put a socket on the 13mm nuts for removeal. The other bolts are in the front of the petal cluster and you remove the nuts from the other side of the firewall panel.
Geoff
I don't know what to tell you geoff. On mine that 13mm nut is right in front of the nut. NO matter where I put the brake lever it is still right there in the way. I tried every angle I could come up with. If the lever could slide a little one way it would be no problem
Jamie, here is a pic of the assembly. There should be only the attachments #11 and #14.
Geoff
My pedals
I removed by pedals this weekend, the red circles are where the bolts attach to the floor.
Rob Watson Red '74 2.0l |
Getting back to your original question, a mis-adjusted (too loose) clutch cable will definately cause you to grind gears when shifting. Make sure the 11mm lock nut on the end of the cable isn't worn and isn't "walking" itself loose as you drive. You may need to put a second nut behind it as a jamb nut. It does sound like it snapped on you. When you replace it,(after you get the cluster rebuild done) make sure it's not crossed or tangled with the accel. cable, and check the cable tube for bends or kinks which could have made it hang up.
Don
Don Kiepert '73 Big Bore '02 GTI 1.8T Race a Porsche - There's more to life than left turns! |
